Results 1 to 9 of 9
    Nov 2010
    Default vw polo strange problem with key help please
    vw polo 2007/09 1.4 tdi edc17 dash m.marelli 6Q0920804J MCU 9S12H256 2K78X all key lost, i read the dump ,have pin and try
    to programming with magic 2 id48 transponder and have incorrect key programming after i try vw can bus transponder and no luck maybe have CsecurIty can someone check for me please if have CS , THANKS
    Oct 2013
    Serbia,Mladenovac
    Quote Originally Posted by keytech View Post
    Pin:7182? No need CS
  3. The Following User Says Thank You to lesakljucevi For This Useful Post:
    keytech (10th May, 2021)
    brend's Avatar
    Oct 2015
    Same where
    What about key prepare?
    Which one tool you use for this job?
  5. The Following User Says Thank You to brend For This Useful Post:
    keytech (11th May, 2021)
  6. #4
    Nov 2010
    thanks i have the pin , i have calculate pin with avdi dump tool , but can t programming the key ,with vcds, zedfull, sbb ,etc
    Nov 2010
    i read the dash with enigma ,maybe something wrong in dash?
  8. #6
    Oct 2013
    Serbia,Mladenovac
    VVDI2 can do chip from dump direct
  9. The Following User Says Thank You to lesakljucevi For This Useful Post:
  10. #7
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Enter PIN>wait 20 min>Adaptation>Done
  11. The Following 3 Users Say Thank You to lupu_sandu For This Useful Post:
    castin (11th May, 2021), keytech (11th May, 2021), rokibar (11th May, 2021)
  12. #8
    Nov 2010
    Hi thanks to all ,in this case i produce transponder with tango by the dump, after programming in car and start ok ,its need to write some ID IN transponder similar to CS
  13. #9
    brend's Avatar
    Oct 2015
    Same where
    Like I said in post 3, first need key prepare then programming and for this job need good key tool not diagnostics equpment.
  14. The Following User Says Thank You to brend For This Useful Post:
