Results 1 to 13 of 13
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Default Audi A1 2012 key programming AKL need your help
    I need to put cluster in service mode my vagpro eeprom reader not working for some reason, can someone change this eeprom to service mode so I can programme the key thanks.
    wembleyhill's Avatar
    Feb 2009
    Fill eeprom dump :
    [VAG with NEC MCU + 24C32 inside] - range 0xCA0 - 0xEDF in hex editor with FF FF ..
    [VAG with NEC MCU + 24C64 inside] - range 0x13A0 - 0x1450 in hex editor with FF FF
    use buttons
  3. The Following 3 Users Say Thank You to wembleyhill For This Useful Post:
    antonypaul (11th November, 2022), p1et (13th March, 2022), super jumbe (10th May, 2021)
    Dec 2008
    Livingstone
    One more info please, after getting CS & Pincode from service mode do I write back the original chip a bit confused.
    Feb 2009
    upload original gonfig add key and update
    use buttons
  6. The Following User Says Thank You to wembleyhill For This Useful Post:
    super jumbe (11th May, 2021)
  7. #5
    lion0304's Avatar
    Oct 2014
    Default Service Mode
    Here your Service Mode dump.
    Write back to eeprom then plug on car and program your key
    If you have FVDI, you can make key on bench direct in to dash.
  8. The Following 2 Users Say Thank You to lion0304 For This Useful Post:
    antonypaul (11th November, 2022), super jumbe (11th May, 2021)
  9. #6
    Dec 2008
    Livingstone
    Last week my Smelecom Eeprom Adaptor got burnt out and I am having bad issue to put the eeprom in service mode, the eeprom adapter not cheap aroung $500 I am going to look for another cheap tool to read and write eeprom on board, what do you all think about the Xhorse Mini Prog is it any good mind you this tool will not automaticaly change eeprom to service mode smelecom does.
  10. #7
    lion0304's Avatar
    Oct 2014
    For eeprom, i have many can do: UPA, Orange, Iprog, VVdi prog, Carprog, TL886.
    TL886 is most used. This job take around 30mn on bench.
    If you do on car, do not forget to save ABS coding first.
  11. The Following User Says Thank You to lion0304 For This Useful Post:
  12. #8
    ghostrider72's Avatar
    Jul 2012
    UK
    Quote Originally Posted by super jumbe View Post
    Just buy VVDI Prog and you will be fine. More capable than Mini crap
  13. #9
    Mar 2018
    Hello.If you don't want to deal with the soldering business, Miniprog is more suitable for you.
  14. #10
    Oct 2017
    EU
    How many topics you want open for the same car?
    When I help you
    PUSH on +THANKS and REP or
  15. #11
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by musti418 View Post
    If you don't want to deal with soldering business, you should stay away from this profession :P (Of course I mean generally, I'm not talking to you, just to clear it up )
  16. The Following 2 Users Say Thank You to p1et For This Useful Post:
    jodge (11th May, 2021), musti418 (11th May, 2021)
  17. #12
    Mar 2018
    you are right p1et i already use zedfull vvdiprog vvdi2 devices. just because it was asked, I wanted to specify.
  18. The Following User Says Thank You to musti418 For This Useful Post:
    p1et (11th May, 2021)
  19. #13
    p1et's Avatar
    Oct 2013
    I know friend, I know
  20. The Following User Says Thank You to p1et For This Useful Post:
    musti418 (12th May, 2021)
