Results 1 to 6 of 6
    Jul 2013
    Latvia
    Default VW Golf 5 cluster PIN codes
    Hi everyone!
    Need to replace instrument cluster on Golf 5, but need pin to code keys.
    Can someone please read pin codes from those files?
    Both clusters is VDO.
    Thanks in advance!
    Nov 2017
    Dobruja
    I might say that eep is not enough. Must read Micronas, too. Or try reading it by obd with a propper tool.
    If you don't have the tool, you might resolder the ipc, or do immo off in ecu.
  3. The Following User Says Thank You to volodin69 For This Useful Post:
    flashtech (14th May, 2021)
    Jun 2013
    2006/-6 and earlier Vdo
    2006/6- and up - Vdo Micronas need to read flash also
    If the 24C16 is from the original car. It would be smart to try to read out the engine ECU for PIN. Since I know most tools dont support this one.
    The 24C32 should be alright.
    With both PIN available. VCDS should solve it.
  5. The Following 2 Users Say Thank You to Weasel3 For This Useful Post:
    flashtech (14th May, 2021), volodin69 (14th May, 2021)
  6. #4
    Nov 2017
    Dobruja
    Quote Originally Posted by Weasel3 View Post
    The same I thought, myself, he might read the pin code from ecu. But if he doesn't have the tools, all we know that VW IPCs have problems with cold joints and could start to resolder. Cheap and easy..
    Maybe he wants to install GTI ipcs on his car, my oppinion...
  7. #5
    Jul 2013
    Latvia
    Thanks for answers. Here is flash from ECU. Or i need to read something else?
    No i just want to swap cluster because on old cluster screen is broken, and MOT cant be passed because of this problem. Second cluster was got for free thats the reason why its need to be replaced...
  8. #6
    Home
    I thing you need EEPROM not flash.
    Keep in mind, English is not my native language.
