Results 1 to 13 of 13
    tunstyle's Avatar
    Default Bmw E46 Ews 3 Sync need
    Hi all, i have a start problem with this car:
    Bmw e46 320D with EWS3 system, the cart don't start and have this dtc 4A42 in engine control module DDE7.
    Anyone check if this ews 3 dump is OK, or renew them please?
    Thank you
    May 2019
    Default please see this one?
    If you want i can do for you Synchronization DME EWS.
    tunstyle's Avatar
    Quote Originally Posted by GeorgeHak View Post
    You can do it manualy?
    May 2019
    Gotta try, send me dump dme.
    tunstyle's Avatar
    With your file renewed, i need sync and after program new Key?
    May 2019
    Yes, you need to program the transponder, then do the EWS DME synchronization.
    tunstyle's Avatar
    Your method don't work. I need good solution to sync or recode ews please
    tunstyle's Avatar
    not solved
    May 2019
    Send me a DME dump, I see if I can do the synchronization.
    tunstyle's Avatar
    Full ecu backup attached in first post
    tunstyle's Avatar
    problem solved by me
    how you solved it? need to make one
