Results 1 to 5 of 5
    electrones's Avatar
    Feb 2012
    Around C.V
    Default BSI Valeo 95256 CLK ERROR/BAD
    Hi friends
    I read this BSI many times this time i have one problem using UPA, CLK error or bad is 0,03v
    annex pic from connection.. i dont undertand why, i had check all connection all appear normal and connected
    Have any other point to connect CLK on this BSI to check
    someone hae this before
    Press "THANKS" button. just one click, CHEERS
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    you need put 2 bridge and read this in 3,3v.
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by Dr. Zoidberg View Post
    Thanks friend
    Thanks friend
    All this was done but still doesn't work which tool can do this bsi by obd!?
    Regards
    Apr 2010
    Gdansk Poland
    ioterminal i think can do. Find manual and check. You can find it on iot site.
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    Quote Originally Posted by electrones View Post
    Thanks friend
    Thanks friend
    Regards
    For This Valeo Bsi, It's Easy Via Obd, ( AVDI, X-Tool, Smok, Smelecom, DP4... ) Can Do The Job Via OBD,
    But Also, By Eeprom Should Be Easy, I Done A Lot Of Never Had Problem, Follow This Pinout, ( Check Attachment ),
    Check Xprog If You Have It, It's Very Good In This BSI
    Regards
    Als
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  6. The Following User Says Thank You to momogsm For This Useful Post:
    arti1 (23rd September, 2022)
