Results 1 to 8 of 8
Thread: Golf 5 Hotstart
    Mar 2021
    Default Golf 5 Hotstart
    Hello can someone please do Hotstart for me on my Golf 5 EDC16u1. ADS Remover solution don't work. Thank you everyone
    tunstyle's Avatar
    Test and report. Pass pm
  3. The Following User Says Thank You to tunstyle For This Useful Post:
    grga59 (15th May, 2021)
    Feb 2021
    Tested solution
  5. The Following User Says Thank You to FcTSolution For This Useful Post:
  6. #4
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by grga59 View Post
    You literally have have a cold start map and hot start map there right next to each other just copy the cold start map to the hot start map job done, why is this easy fix still getting asked for is beyond me plenty of vids on YouTube
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
    Mar 2021
    Still can't figure out how to do it and tunstly map doesn't work
  8. #6
    Aug 2013
  9. #7
    May 2021
    Hello and I have a problem with a warm start. The car is a Golf 5 1.9 TDI BKC 105 pd. Can you give me a fixed file.Thank you in advance.
  10. #8
    Dec 2020
    Quote Originally Posted by Beckshot View Post
    Post your Flash file and ecu parts numbers
