2013 smart key fiesta immobiliser error
Results 1 to 4 of 4
    Aug 2020
    Default 2013 smart key fiesta immobiliser error
    After fiesta was stolen and recovered, it keeps getting an error message “immobiliser malfunction service now”.
    Fault codes that appear are B10D8 (less than 2 keys programmed to the car). But there is 2 keys programmed.
    Any ideas?
    Tried deleting & re adding keys again?
    Sep 2016
    You need distinguish that probably numer of programmed remotes/keyless can differ from transponder.
    May 2021
    Remember cluster is number one failure affects all Ford models I spent hours on two Ford focus both with the cluster fault so check solder joints on cluster first with engine malfunction even the manual
    Ford focus was giving me transmission malfunction this vehicle are a nightmare when they go wrong my Ford focus nearly killed me two times cutting out on motorway with the same problem.
