the checksum is bad and is a bad read flash this original file and the car will start pass in pm
I made a backup of my ecu with mpps v21 and after that I have an error p0602
suddenly the vehicle does not start anymore , but the ECU is still visible and readable.
Can you check my stage 1 file 163cv @ 195cv because i don't know if I can re-inject it .
Or any solution
Thank you
ECU ME7.5
Bosch_HN_0261208228
SN_1037368069
VWH_8E0909518AL_0002
boblepongeur (16th May, 2021), redonerj (17th May, 2021)
thank you for reply !
can i use mpps v21 to inject the file?
yes buddy you can flash this using mpps v21 although i would not recommend using mpps v21 clone because it has time bomb and breaks after
about 10 flashes use mpps v18 they dont have any problems
Oh F~~CK yes !
I wanted to take a read and it burned down, so a rush buy on amazon.
What bad luck !
buy a decent mpps v18 from ebay or amazon and stick with that forget mpps v21 there terrible and did my file work out for does the car start now
Okay,
Thanks for reply
