Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 117
Thread: Help BMW ISIS
  1. #61
    can anyone help me
    Problem with instal ISIS
    NTLDR is missing?????????????
    Problem solved
  2. #62
    Default BMW 3G ICOM A+B+C interface
    Hello all,
    Please find the ORIGINAL ICOM SET photos attached.
    To prove the photos is current i use somebody name on this forum DASH STOINEV on the items.
    Regards,
  3. #63
    Sep 2010
    could someone please PM me the ispi and itools DVD link?
    PLEASE!!!
  4. #64
    Qrius's Avatar
    Quote Originally Posted by homut007 View Post
    PLEASE!!!
    Nice first post since Sept 2010
  5. #65
    https://t.me/pump_upp
    I have problems installing ISIS 2.8. Not all VMs are created only ANTERES. VMETK and VMSCORE are missing. Any suggestions?
  6. #66
    Sep 2010
    recreate VM:
    OPEN P:\IBase\Basis\System_API\TestScripts\Test Virtual Server Controller.cmd .
    Edit cmd: %JAVACOMMAND% com/bmw/ibase/test/TestVirtualServer -name VMANTARES -mem 2048 -vhdname VM_Antares_HDD1 -master VM_Master_HDD1 -destpath V:\VM_Guest_Antares -iso V:\VM_ISO\ORACLECLIENT.iso -removeexisting
    %JAVACOMMAND% com/bmw/ibase/test/TestVirtualServer -name VMSCORE -mem 1024 -vhdname VM_SCore_HDD1 -master VM_Master_HDD1 -destpath V:\VM_Guest_SCore -iso V:\VM_ISO\ORACLECLIENT.iso -removeexisting
    %JAVACOMMAND% com/bmw/ibase/test/TestVirtualServer -name VMETK -mem 1024 -vhdname VM_ETK_HDD1 -master VM_Master_HDD1 -destpath V:\VM_Guest_ETK -iso V:\VM_ISO\ORACLECLIENT.iso -removeexisting
    AND run Test Virtual Server Controller.cmd
  7. #67
    homut007
    For me directory P:\IBase\Basis\System_API\TestScripts does not exists and dont know why
  8. #68
    ISIS 2.8 installed. changed files for battery check from 2.7 and forgot to make a backup. Now WSM manager cant start. Need 3 files from ISIS 2.8
    P:\ibase\wsm\apps\manager\conf\application-processes.xml
    P:\ibase\wsm\apps\manager\conf\sheduling.xml
    p:\ibase\wsm\apps\shared\decl\snmp-config.xml
    SOLVED Reinstalled WSM Manager
  9. #69
    hello it is he need
  10. #70
    Nov 2010
    thank u very much davito1!
  11. #71
    Mar 2011
    Default isis registration
    Quote Originally Posted by cartocar View Post
    Anyone to know how to register ISIS?
    I have already installed BMW ISIS Server DVD Moded 2.7.0.31 on VMware that have three green light on ISTA , ETK and ISPA but I could not install above three sofeware continue . Because I did not registration
    So, anyone can help me how to register BMW ISIS?
    Check this ->http://www.digital-kaos.co.uk/forums...82/index3.html
    Then READ: gkouou's post,then tonemoz's post,and then mine(there's a serial in localserverall.log,at least there was for me...)
    (right under tonemoz's...)
    Then click on wrench icon->select language and BMW options.WSM will go blue..
    P.S. if u find how to register isss share pls.
  12. #72
    Mar 2011
    Default ISIS launcher problem
    (After countless (re)installas of isis,here's where I am)
    I have installed isis and did the offline reg. Then installed the isis launcher,and
    everything worked fine until I restarted the VMware client
    (win 2003 server->shutdown->restart). And when win 2003 loaded ,isis doesnt work anymore.
    Isis launcher notification says :"cant connect to isis". All 3 VMs are offline,but I could turn them on
    (I dont think it would matter)
    Isis doesn't listen on 195.168.1.5,port 80 (that's the ip of isis).It does on 127.0.0.1. Stunnel reports problem.
    And here's a stunnel error log:
    2011.05.25 22:28:53 LOG5[2368:3612]: stunnel 4.26 on x86-pc-mingw32-gnu with OpenSSL 0.9.8i 15 Sep 2008
    2011.05.25 22:28:53 LOG5[2368:3612]: Threading:WIN32 SSL:ENGINE Sockets:SELECT,IPv6
    2011.05.25 22:28:53 LOG5[2368:3344]: No limit detected for the number of clients
    2011.05.25 22:28:53 LOG3[2368:3344]: Error binding wsm-manager to 0.0.0.0:23007
    2011.05.25 22:28:53 LOG3[2368:3344]: bind: Permission denied (WSAEACCES) (10013)
    2011.05.25 22:28:53 LOG3[2368:3344]: Server is down
    System Diagnostics Report V4.50.10 is attached.
    Looks like C:\Program Files\BMW AG\ISIS-Launcher\WSM-AgentProxy.exe has tcp port 23007
    But I somehow dont think this is the only thing messing the ISIS...
    Thanks.
  13. #73
    May 2011
    hi guys i need tha last version of vmware
  14. #74
    Hi guys i want to install all systems needed for BMW Diagnostic and programming and i don't know the whole system could any one explain to me the whole system and if you can provide me with the data needed to install it links and manual instructions and keygen if needed and the specification for the computer needed to install the systems on it many thanks in advance
    and the prices for hardware needed like icom and most and all connections please
  15. #75
    Mar 2011
    Quote Originally Posted by Duplex View Post
    Why dont you use torrent, or if you like file sharing sites,
    try itunas search at SETRST's blog - Stuff I find useful and helpful
