Results 1 to 9 of 9
    Jan 2009
    Default P307 not works clima after bsi replacment
    Car is 2006 valeo bsi
    Org bsi is J01 donor is J03
    I programed all,car started ok, but clima not work,compressor not goes on.
    In bsi configuration there is option klima present or absent
    Now dtc in clima is no communication with BSI
    Any tips?
    P.S. Also radio beeping even I put org vin nr for car. Before klima "worked" and radio "not" beeping,but thats his words,old bsi burned he said
    Jan 2009
    Also, friend telling me that there are differences if bsi is from diesel or petrol car,even in configuration can choose petrol or diesel.
    Is it right?
    Or someone send tested virgin for J03 bsi
    May 2016
    The hardware must be the same, put BSI virgins, configure, then should be works!
    Jan 2009
    Which nr is hw on labels?
    May 2016
    Send picture the original BSI
    Jan 2009
    In first post are both labels or you mean pcb inside?
    May 2016
    FNR if the other BSI have the same it should be work
    Jan 2009
    ...97380 one
    ...97580 other
    Not same
    Jan 2009
    Solved
    Tnx to all
