Thanks I going to try all this advices and let you know.
best regards
best regards
Hi, I tried all the advices, try it several things uninstalling all several times and reinstalled, nothing. Tried several trucks same result. I just install new OS winXP with fresh cummins installation and same thing. I used the the 7.2.0 crack but it's given me the same result. probably because I used the kg to make fleet and ecm pw removal keys and it's causing the problem.
Anybody have solid solution for this issue?
I'm going to try fresh OS and insite installation without the key and report.
try an older version
just use a key pro and calibration fleet, so works well for me
I don't believe the whole pro vs pro plus is the real problem here.
mine does the same thing, when not connected it says PRO PLUS and as soon as I connect it says PRO, Mine has been great, Are the codes you are trying to clear ACTIVE or INACTIVE? PRO gives you all access, its the highest level cummins usa uses, not even my freightliner or cummins dealer have ever heard of pro plus. If anyone knows the difference let us know.
With cummins you can not clear an active code, it must be repaired or resolved then it turns inactive then you can clear it. What code do you have?
Please let me know.
Hello everybody,
I need help with ECM database.
I use the Insite 7.3 but when I try to download the engine software I get this message:
The Calibration Database on this drive have expired and will be purged.
How can I solve it? The reinstall doesn't help.I have May 2010 Insite v7.3.
Hi, i nedd ur help please, When i open Insite, inmidiatly come a square " insite start close " and never open.
What can i do ?
Thanks in advance
Check your laptop will suit an insite installation,
Did you download from a reputable location?
uninstall insite and re-install
get 7.4 from here
https://insite.cummins.com/insite/index.html
Does anyone know what the latest incal disc is? I know we are in November but not sure if a November disc is available or when it will be. When do dealers receive their discs?
Thanks in advance
hi friend where i can download version 6.3 please for torrent if is possible
