Results 1 to 10 of 10
    Mar 2017
    Default BMW X1 F48 ACSM Internal control unit fault
    Hello all
    I have an BMW X1 F48 with airbag module ACSM - internal contorl unit fault (930BA4-FAULT).
    EEPROM 95256 on module
    ACSM NUMBERS:
    6577 6837162 01
    more info on fotos.
    superjet's Avatar
    Aug 2018
    check this file and report.
    pm
    Mar 2017
    It doesn´t let me download the file. The web promps up with loggin page.
    Jan 2022
    Hello superjet, would you share your details on this fault? I have same fault on the same car.
    Thank you, so much!
    superjet's Avatar
    Aug 2018
    Quote Originally Posted by duner View Post
    Thank you, so much!
    Upload your file......
    Jan 2022
    THank you for your message! I'd have to read it first, - just got ESys down, is it a proper tool? THX again!
    I have also original ACSM, as one with error is a donor. Original has some water damage though, - that's what behind this project.
    Can someone help me to clear this file from 6577 6818812 with 039BA4 Internal control unit error
    Thank you
    Can someone help with my file please?
    Thank you
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Your repaired file, report back.
    Scripts for Multi-PROG
    Best regards.
    Dragon
  10. The Following User Says Thank You to dragon100 For This Useful Post:
    ypt (13th March, 2022)
  11. #10
    Quote Originally Posted by dragon100 View Post
    Hello friend,
    Is not working.
    Same
    930BA4 internal control unit fault still there, and wont allow me to flash it.
