Hello all
I have an BMW X1 F48 with airbag module ACSM - internal contorl unit fault (930BA4-FAULT).
EEPROM 95256 on module
ACSM NUMBERS:
6577 6837162 01
more info on fotos.
Hello all
ACSM NUMBERS:
6577 6837162 01
more info on fotos.
check this file and report.
pm
It doesn´t let me download the file. The web promps up with loggin page.
Hello superjet, would you share your details on this fault? I have same fault on the same car.
Thank you, so much!
THank you for your message! I'd have to read it first, - just got ESys down, is it a proper tool? THX again!
I have also original ACSM, as one with error is a donor. Original has some water damage though, - that's what behind this project.
Hello,
Can someone help me to clear this file from 6577 6818812 with 039BA4 Internal control unit error
Thank you
Can someone help with my file please?
Thank you
Your repaired file, report back.
Scripts for Multi-PROG
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
ypt (13th March, 2022)
