Results 1 to 8 of 8
    May 2021
    France
    Default Seat leon 1p 2.0 ppd 1.2 need some pointer
    Hello, guys could you check this map out i'm trying to remap my seat leon 1p 2.0 tdi ppd 1.2 03G906018GP !
    could you guys plz look at it and give me some advice on what sould be kept and what needs to be remade many thx!
    also if you could explain how to put a Hardcut on this ECU and i lost the launch control after remap
    thx in advance!!
    Dec 2019
    UK
    Post original file also
    Genuine WinOLS
    Stage 1|2|3
    EGR DPF ADBLUE IMMO
    Free Service for all DK Members
    Engine Coding Solutions
    PLEASE DONT MESSAGE ABOUT PASSWORDS, POST YOUR OWN FILE AND ASK FOR HELP
    May 2021
    France
    Default ori.file
    here you go !
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by vaynah View Post
    thx in advance!!
    To be honest tune not good alot of maps missed
    Torque limiter misssed
    Smoke map missed
    IQ limit missed
    Boost limit maps missed
    Drivers wish maps missed
    So this map would run into limp mode all the time or just keep pulling boost.
    For Hardcut 0 out last column in duration maps and change rpm axis where you want the cut
    Here is a map pack attached for you should be able to correct and change missing maps
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  5. The Following User Says Thank You to chrisimerk For This Useful Post:
    vaynah (15th May, 2021)
  6. #5
    May 2021
    France
    Thanks a lot !
  7. #6
    May 2021
    France
    Default how about this one ?
    i tried to redo it could you take a look when you have time and share your thoughts ? Thx
    i tried to understand the smoke limiter map but with the way the axes were done, thought it was better not to touch it
  8. #7
    May 2021
    France
    It was not good att all
    so i done this one but it's good only at start
  9. #8
    May 2021
    France
    Default last modif
    it's on this one now
