Results 1 to 2 of 2
    May 2021
    Default Renault Clio IV - DASH reset
    Hello to everyone.
    I'm having a problem. I purchased a Renault Clio IV in which the previous owner had changed the kilometres on the dash.
    I checked with an OBD interface on the ABS and discovered the correct kilos. So I believe the previous owner only changed the km by changing the dash while blocking the ABS communication.
    However, the Trip Computer is no longer operational due to the TDB/ABS synchro blocked. I'd like to reintroduce the Trip computer functionality.
    According to my understanding, I need to flash the original firmware on it, which I don't have.
    Do you have any suggestions for dealing with this issue?
    I have an OBD2 interface as well as the Renolink software.
    Sep 2021
    hello. did you solve your problem with the dashboard an trip meter? I have the same problem with a captur. thanks.
