Results 1 to 5 of 5
Thread: Opcom 1.99 fake
    Jan 2019
    Default Opcom 1.99 fake
    I own this pcb, it can be made downgrade to 1.39 to read corsa C instruments ?
    Or should I go for RL or RQ chip? RL can be down to 1.39 ?
    https://imgur.com/a/2oc2wje
    Dec 2014
    PL
    Hi.
    To change the firmware you need an interface with a real PIC 18F458. Disassemble the casing and check which PCB you really have. In the pictures, only the third interface can change the Firmware. Upload photos of both sides of the PCB here.
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    Col19 (3rd June, 2021)
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Quote Originally Posted by Andr33iy98 View Post
    HI, were you able to read and program the instrument cluster of the Corsa C with your Opcom?
    What version of firmware did you use, please?
    Thanks.
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
    Jan 2019
    1.39 works on corsa c
    Yhoni's Avatar
    Jun 2014
    Ok friend, and what program and version do yo use, please?.
    Thanks.
