Results 1 to 11 of 11
    Dec 2017
    South American
    Default VOLVO S60 CEM CLONE
    HELLO ALL DEARS!
    I NEED HELP, I HAVE VOLVO S60 2011 T6 WITH CHANGING CEM,
    I CAN READ ALL DUMPS WITH VVDI PROG. P-FLASH, D-FLASH, EPROM.
    BUT I TRY WRITE AND I RECEIVED ERROR IN ERASE. ANYONE CAN HELP ME, PLEASE !!
    CHIP IS RENESSA: 32R R5F64524
    I TRY WITH VVDI PROG AND UP400 AUTEL MAXYS
    ANY TALK ME OF IO/TERMINAL
    Holtek's Avatar
    Jan 2010
    Poland
    If you have Data Flash, use IO Terminal. Load to IO Terminal Data Flash and make a full copy.
    Nov 2017
    Dobruja
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by Holtek View Post
    load data in ioterminal and get "12 digit password" then its cloning time
    for P1, P2 (CEM H-L) password cracker exits direct via CAN-H CAN-L extract it and cloning without open CEM module
    smokey08's Avatar
    Mar 2010
    Essex, UK
    I'm trying to do the same on a V70. did you manage to clone yours? Can read and write e2data, but can't erase data or flash .
    Sent from my Pixel 5 using Tapatalk
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by smokey08 View Post
    what does autel support say?
    Apr 2016
    Quote Originally Posted by ricked View Post
    check connection, try later, not supported version, user fault .... what chinese can say
    smokey08's Avatar
    Mar 2010
    Essex, UK
    Quote Originally Posted by K1nd3r View Post
    This looks like a response from abrites. Would probably get better results messaging penko to see if he can add the device to my UUSP-S.
    ricked's Avatar
    Apr 2016
    Europe
    i think if you do it with xprog ori you can read it...
    Oct 2017
    Moldova
    Someone tried to resolve the issue with the Chinese ... from the outel ... maybe you can still achieve something from them?
  11. #11
    ricked's Avatar
    Apr 2016
    Europe
    xprog ori works, tested
  12. The Following User Says Thank You to ricked For This Useful Post:
    fuzz1 (12th December, 2022)
