Results 1 to 4 of 4
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default BMW E90 screen size edit
    Hello
    I have a BMW E90, which on the screen, at the bottom a part of it does not work, it is as if they have changed the car screen with a bigger one, is there a way I can use the whole screen?
    does it want programming?
    if so, how?
    thanks.....
    Jan 2019
    Need coding...just all
  3. The Following User Says Thank You to navserwis For This Useful Post:
    Panathaole (7th June, 2021)
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    can help with instruction of how i can set the correct size of the screen? (with inpa?)
    May 2021
    you have to code with NCS Expert 0x63 APL
    You change:
    CID_CCC cid_high
    CID_TYPE static
