Somebody have any ideea what these bytes meaning ? Please i need some help to solve this problem.
Hello everyone ! i installed on my audi a6 c6 headlights with led, previous was halogen. Now on dashbord have error with bulbs. Vcds doesn't have any option for this car to turn off cold diagnosis, the only way to solve my problem i think is to read eeprom from bcm and modify the byte that contain cold diagnosis. I already read the eeprom from BCM but i don't know which byte have the info. I tryed to change some values but with no luck. Could somebody help me...maybe someone knows how to do it or tell me where i could find some infos.I uploaded the bcm dump here.
Thank you !
Cant view eeprom file whilst naked in bed, but your going be looking
at thousands of possable hits.
can only think
online see if will toggle
used bcm that does the job
read eeprom, put halogen bulbs in, clear codes
unplug halogen bulbs see what bytes changed
that entire line fill with 00
fit reistors but that crap idea
Nice idea, i will try it and let you know what happened...thanks
I done everything you said, but no changes into eeprom...i changed almost every byte to 0...still caming the error and bcm makes cold diagnosis.In the picture that i uploaded i read the eeprom marked with green...that marked with red i m not sure if is an eeprom...i couldnt read it.
So
1) give up
2) not that module
3) buy correct module
4) try on line coding
What does it mean on line coding?Can u give me an model number for the right module ?thanks for your replys.
On line coding
where some utter cockwomble had made is so YOUR car, that YOU own >>MUST<< go to main dealership
even if the nearest dealership is a seven hour boat ride away, connected to internet
where some crout checks that the dealership is real, then changes the settings
not my job part numbers try. Google. Parts link 24
oh there is a thanks button, if stiff. Press harder
babarik (14th June, 2021)
