Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Dec 2009
    Sweden
    Default X24C01 read error
    I am trying to read a X24C01 in circuit with soic clip but keeps getting verifying error.
    I use a X-prog T and DIP to SOIC adapter cable.
    What am I doing wrong ?
    Nov 2009
    PH
    while the I2C bus it-s busy U can't take control with a external programmer and read eeprom . U can try to leave I2C bus free, by soldering a wire between Quartz osc pins of MCU
    Dec 2009
    Sweden
    How do I find out what pins to short ?
    The MCU is a NEC D75P518GF and the radio is a Volvo SC 801
    And how do I know when I need to short the Quartz and not ?
    Have to try and find a datasheet for that MCU, I suppose.
    Thanks for helping me, its my first try with both this equipment and in circuit programing.
    Have only used a eeprom programer before.
    Jun 2009
    Desolder the eeprom and read it - it is the only safe method for a beginner.
    Dec 2009
    Sweden
    I am already familiar with desoldering and reading eeprom onboard, now I want to learn how to do ICP on eeprom, next will be desoldering MCU but then I will have to get a hot air soldering station first.
    I have a bunch of old volvo radios to practice on,
    so it doesnt matter if I screw up.
    Just want to learn.
    Dec 2009
    Sweden
    Soo...I ended up desoldering the eeprom cause I couldnt get it to read in circuit.
    Now when I put it in the programmer, its all f**ked up.
    Question is why...
    1. I destroyeed it when trying to read it in circuit
    2. I destroyed it when desoldering it
    3. It was already destroyed
    What do you guys think ?
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by pinch View Post
    Question is why...
    Not easy to read Xicor eeproms on board mate ... Shitty things that corrupt at the drop of a hat....sorry .. Reading in circuit any eeprom can fcuk up ... if it is easy to access rip the fcuker off ..it takes seconds ..and at the end of the day .. you will have a dump to save .......It's nothing to do with being Inexperienced ... I've been doing it for a while now .... And although I often read 24c'... in circuit ....If i don't have a dump on file ...i still remove them .....
    Dec 2009
    Sweden
    Hmmm......I am rally having some problems here...
    Took another radio and desoldered the X24C01 without trying to read it first and without using any force, used a solder wick.
    When I try to read it all I get is "device not ready or bad", I am using the Xprog -T and a SOIC clip with DIP adapter.
    Even bought a new 24LC01B SOIC by Microchip and it both reads and writes fine.
    I cant believe I would have f*ked up this eeprom when desoldering it, the first one ok, but not this one.
    Does the xprog have a issue with the X24C01 ?
    In the DPD program it says Xicor X24(C)01A, on the chip it says
    X24C01
    423 C
    Am I choosing the wrong eeprom in DPD ?
    Can I replace the X24C01 with a Microchip 24LC01B ? (with my luck probebly not)
    Dec 2009
    Question is why...
    One possibility of this when trying to read this chip in circuit and with using IC clip is putting the clip on the wrong side. The IC pins of ground (Vss) and Vcc (Vdd) are transversely lie on pin 4 and 8. Let imagine when the clip is wrongly fitted. I had the same bad experience but never verify it again. You can try again with the new chip and let us know .
    Dec 2009
    Sweden
    I took a look at the datasheets for the X24C01 and the 24LC01B and noticed that both had the same pin layout.
    VSS on 4 and VCC on 8.
    The strange thing is that in my Xprog -T manual it says the DIP socket has VSS on 1 and VCC on 8.
    Tried to switch pins 1 and 4 and still no luck reading the X24C01.
    If the VSS really is on pin 1 on the programer it shouldnt have read and write the 24LC01B.
    Still VERY confused about this.
  11. #11
    Meat-Head's Avatar
    OK so you have a silicon chip that has switched to overload so why don't you post details of what you are screwing, err doing or simply ask PremierD if he can dump on you.
    Then you can try a new dump in your new chip and see what happens.
  12. #12
    Dec 2009
    It might say not completely. On several programmers when they do stand alone programming on this chip they connect P 1,2,3,4 and 7 together and to ground. But this should give no diierent effect if my assumtion of the reverse power supplying is the cause. Look at the link as an example PonyProg - Serial device programmer
  13. #13
    Dec 2009
    Sweden
    M-H -
    I have a bunch of old Volvo double DIN radio casette players without the codes.
    They are from the middle of the 90:s so they are not sellable, so I use them for practice, if they get ****ed up=no biggie.
    Just trying to get the hang of reading these little x24 f**kers.
  14. #14
    Dec 2009
    Sweden
    Anyone here who has a Xpro-T and has had sucess in reading the X24C01 ?
  15. #15
    Nov 2009
    I use Martech I2C clip to read 24c01 eprom from Volvo radio in circuit without problem!
