Results 1 to 15 of 18
    Default A3 Cluster 93c86 fairchild
    Has someone mileage location on 2003 audi a3 93c86 as need correction on attached file ?
    Rito's Avatar
    You need put more information for others can help, and how many mileage you want.
    needs 91810 miles
    Land of Rocks
    Try to read the dump with an eeprom programmer. Must be 2048b.
    i did read with eeprom programmer size correct but was crypted sorted now thanks all for your replys
    USA
    I don't think your dump is correct try reading again with 16 bit and post again with the original mileage.
    Dump was fine if you read above post job is now sorted thankyou
    einet's Avatar
    Hi ,
    One question, on the dump the milage position whose
    Car type: Audi A3 - 93c86 - 2003 year
    The mileage is stored in the next lines:
    0570: xx xx xx xx xx xx xx xx 00 01 E6 28 xx xx xx xx
    05D0: xx xx xx xx xx xx xx xx 00 01 E6 28 xx xx xx xx
    where the next bytes:
    00 01 E6 28 - is a mileage
    and waht i see in the dump is D1 3A B9 D5 and 37 65 58 7B
    What i make wrong?
    Above dump is crypted so tachosoft location no good !!
    einet's Avatar
    can You explain this "crypted" better?
    einet
    load file in this proggy all will be explained remember cluster is in km not miles
    hi what programmer did you use to read/write to this eeprom
    i have same problem ,and bought r250s programmer only to find i need an r200
    so my only option is now to remove eeprom and buy programmer
    any help would be appreciated
  13. #13
    yasser's Avatar
    Bulgaria, Varna
    Here it is with corrected milleage.
  14. #14
    anyone help ?
    everytime i try to dump eprom file size is correct but with the above program it states this dump is not supported ?
    has been read in 16 bit mode nd 8 bit mode with no difference .
  15. #15
    Default I am trying to learn about this....
    I have a couple of old dashes to experiment on - but what is the best choice (not too much cash - Please!) for a programmer? Help!!! - Thanks!
