APRILIA RS 125 MC908LJ24 0L83S
Results 1 to 11 of 11
    Mar 2017
    37
    Default APRILIA RS 125 MC908LJ24 0L83S
    2007 APRILIA RS 125 DASH WHIT MC908LJ24 0L83S
    Can someone tell how to read this board?
    Pinout Conector 20 pins
    pin1 +12v
    pin6 ground
    pin11 +12v
    Jun 2016
    Budapest HUNGARY
    34
    connect 9 pin
    in row 8 and Osc
  3. The Following User Says Thank You to f2f2 For This Useful Post:
    r1yamaha (9th June, 2021)
    Mar 2017
    37
    I connect the 9 pins
    What type of Mcu you select whit Orange 5 ???
    my Orange 5 clone dont have the MC908LJ24
    Apr 2018
    EU
    50
    MC908LJ24_CFQE have Password security
    If i helped you with your problem, please press the Thanks button.
    Ask your questions in the forum, no response on private messages.
  6. The Following User Says Thank You to Diagcar1 For This Useful Post:
    r1yamaha (10th June, 2021)
  7. #5
    gogalv's Avatar
    Aug 2010
    19
    You have to buy the original, then everything will be.
    You'll need pictures from all sides mate .... ? PremierD
  8. The Following 2 Users Say Thank You to gogalv For This Useful Post:
    chris781 (10th June, 2021),r1yamaha (10th June, 2021)
  9. #6
    Mar 2017
    37
    Yes sometimes only original tools do the works
  10. #7
    Jun 2016
    Budapest HUNGARY
    34
    If this connect info
    I've met so far With 2 types of connections
    different only Clock signal pin place
    Vss direct 0-Ohm PTC1 and PTA2
    Vdd direct 0-Ohm PTA1
    Reset
    IRQ
    PTA0 communication
    OSC1 clock
    programmer connect wire number only 6
  11. The Following User Says Thank You to f2f2 For This Useful Post:
    r1yamaha (11th June, 2021)
  12. #8
    gogalv's Avatar
    Aug 2010
    19
    Quote Originally Posted by f2f2 View Post
    If this connect info....
  13. The Following 3 Users Say Thank You to gogalv For This Useful Post:
    f2f2 (11th June, 2021),PremierD (11th June, 2021),r1yamaha (11th June, 2021)
  14. #9
    Jun 2016
    Budapest HUNGARY
    34
    gogalv
    i look photo
    SS DIGITEK D03F32R7
    but this connection same CS D03F32R6 and D03F32R8
    I presented a different kind board
    CS D03F32R5 and Osc1 pin in connector
  15. The Following User Says Thank You to f2f2 For This Useful Post:
  16. #10
    Mar 2017
    37
    Wiring Diagram
  17. #11
    Sep 2016
    Hungary
    516
    pinout.jpg..........................
  18. The Following User Says Thank You to kismurmi For This Useful Post:
