because you want a blank board file due to bad reading and corruption, take any file that corresponds to that board and put km 0
PremierD (13th June, 2021)
300gdturbo (13th June, 2021)
thanks for the file!
Are you sure the dash is virgin only of first two lines are FF?
Need to have unlocked, because I need to change diff ratio, kick the TCO and change km.
This should be possible by DAS if dash is virgin/unlocked.
If you zero the kms .. you can program with DAS ..
Thanks for your answers!
Just tried the file provided by waltermanuel and anotherone with 0km (first two lines FFFF...).
DAS and VEDIAMO still tell me, that the dash is locked.
Did I do anything wrong at resetting to zero kms?
Hi.Dash unlock.mileage needs to be adjusted
tried your dump with and without milage set to zero.
DAS and VEDIAMO always say the dash is locked and not programmable.
Am I doing something wrong?
Hi.Try .............
Thanks for the file! Will have a try in an hour.
Shall I change the first two lines to FF or keep them as you sent?
what mileage is needed
the needed milage is 345035km, but dump needs to be unlocked, so axle ratio can be changed.
write this dump.Coding STAR-DIAG
thanks for the file.
Mileage is 153540km, and is still not unlocked.
Just tried about 20 different dumps on the 93c66, but none of them is unlocked. Some did crazy things, but with none of them the dash was programmable with DAS or VEDIAMO.
Is it even possible to get the dash fully unlocked to VDO delivery condition by the 93c66?
try dump swap
300gdturbo (14th June, 2021), trumnica3 (19th May, 2022)
