Is it safe to use Dreamup with Dm500c boxes currently being sold by DVBmonkey and Dvbseller, etc
I hear Dreamup kills clones.
it was a particular image that was released by gemini that killed the clones, not dream up.use the dk image and you will be safe
hi
don't know if it was just a coincidence used dream up on a dm 500c
from dvbseller with use network ticked now ethernet port does not work
on seconed box unticked use network box when using dream up
etherner port works ok
i have used dreamup with a 500c box from dvb monkey and its working fine. Dreamup is not a image an image is gemini dk image etc dreamup is a flash programe like flashfxp
Is there any step by step tutorials I can have a read of anywhere?
Thanks for quick replies everyone - sorry got a little bit confused as not using DM500C yet - still the clarified issue and confirmed that Gemini image should be avoided. Is it just 1 particular version of Gemini that is a killer or is it all Gemini images
It isnt on all gemini images and people still use gemini but i suggest if your box is a clone which it will be then do no go near it.
Unless you fancy learning how to jtag and recover your box.
hi
I am new... so sorry if i am asking stuip questions ;-)
i have got a dm500c.. how do i know if it is a clone?
or is c already standing for clone??
thanks a lot for your help!
if it has a screw in cable end like vm boxes then its a clone, if you need the push in aerial adapter, it isnt a clone!
