Results 1 to 10 of 10
    May 2021
    Default Volvo Airbag crash reset, how to access eeprom?
    Never mind
    rafal's Avatar
    UK - PL
    use brain.......................
    need help
    now my goal is to buy xp-005
    who will help?
    May 2021
    Quote Originally Posted by rafal View Post
    Yes, that's why I am asking from this forum and not trying and failing to do it without enough information.
    rafal's Avatar
    UK - PL
    Quote Originally Posted by elektoni View Post
    so change job if you are asking simple things....................
    need help
    who will help?
    May 2021
    There's no need to be salty here. Anyway, by saying it's simple actually helps me. Then I know there are no tricks on it. So, maybe it's about trying to remove the press-fit connectors and then solder them back on?
    Jul 2015
    just push out capacitator
  7. The Following User Says Thank You to oskars268 For This Useful Post:
    elektoni (16th June, 2021)
    May 2021
    Okay, for the others to know, I wiggled the press-fit connectors a little bit and then pryed out the battery.
    Can someone please check if this file has crash data? My tool says it's clean, but please verify.
    EEPROM 95128
    Volvo V60 2011
    Airbag sensor P31334542
  9. The Following User Says Thank You to elektoni For This Useful Post:
    tepSIJA (17th June, 2021)
  10. #8
    Nov 2019
    Hello
    This is my first post and I'm glad to help.
    Please, this is the fixed file.
  11. The Following User Says Thank You to Ediboss For This Useful Post:
    elektoni (18th June, 2021)
  12. #9
    May 2021
    Quote Originally Posted by Ediboss View Post
    Hello
    Thank you! I am glad to give you the first "thanks"
    Did you find the crash data from the file? So, it was not clean dump?
  13. #10
    Nov 2019
    Your file had information about the event (crash data). My file inserted is with an event removed.
  14. The Following User Says Thank You to Ediboss For This Useful Post:
    elektoni (1st July, 2021)
