fragga (18th June, 2021)
try and report
immo off ok
File off attached....
CMD | Alientech K-Tag | Batronix
+++ NO Passwords +++
Just press THX & Rep if i helped you....
All the fils provided are just the same, I checked, and still no SPARK injectors are working but missing spark ,story is the ORIGINAL ECU was water damged and last the owner lost it, so now I have two ECUs ,
I want to do IMMO OFF because ECU needs coding with IMMOBILIZA,
Here immo off , enjoy
fragga (19th June, 2021)
Still no luck yet, I don't know if this ECU has IMMO OFF
hello my friend
this is ur file
please do not forget thanks and reputation
PASS PM
GoodLuck
PROBLEM SOLVED!!
Thank you all Friends, the files provided here were all good, only the problem was that after connecting ECU back to the car, the Car was locking again the ECU , so solution was to do WRITE PROTECTION after writing the EEPROM by UPA, some cut wire 19 that goes from ECU to IMMO ,but for me it didn't work, but after I did WRITE PROTECTION, WORKED !!
keyzex (22nd June, 2021)
