do you have odis e ?
wbr.
PierreTheron (22nd June, 2021)
Yes and does not want to flash it .
I have ecu 06A906033CA for manual vehicle that i am trying to flash to 06A906033CD
Car came without ecu Etka gives 06A906033CD as only replacement
So immo is active on this ...
Using pincodes to adapt the ecu also not working..
( If i copy dashboard CS to ecu eeprom with fvdi i can get ecu coded and it starts but does not adapt the vin from the dash to the ecu ..) So it loses immo after ignition is switched off for a while ..
Immo off only makes the car run but ecu gearbox coding is still manual (71) .and not allows me to change it to (75)
I got .sgo file that i changed to bin file for 29f400
Then had to edit and mix it with the 29f200 from the 06A906033CA ecu
But must be doing something wrong as ecu is dead if i load the file ...
Will try and checksum it with winols tonight ..
return the ecu to original state (manual.ca) ... just do immo off (on 93c86)and get car starting ... don't look to vin ... odis e only want car can start ... flash with odis e with cd ... then you may get an error of chechsum or coding error something like that ... because flash is auto and coding is manual 0000071 so needs to be changed to 0000075 ... here only 75 will be accepted ... do this on same order i had sad ie (flash then coding) ... sure all will be fine
wbr.
Thanks m8
seems my odis engineering 9.2.2 is faulty on this ecu type .
It does not want to flash .
So managed to flash it with vvdi2 on the bench .
After this i could change coding from 05 to 75
Here is the 29f400 file after flash and coding ...If someone needs it ..for future use..
fuzz1 (25th July, 2021), rafal (26th July, 2021), vanos batam (9th September, 2021)
Is the problem totally fixed now?
Yes m8 . Car is solved completely..
fuzz1 (26th July, 2021)
My Odis i bought could not progam the new soft update from odis .So wtf i believed that ,,
Then with luck i tried update with vvdi2 .and it worked 1000000%
