Page 1 of 14 12345611 ... LastLast
Results 1 to 15 of 198
    Default Alexs307 - peugeot technician
    Hi, guys. I find you forum very interesting. I am specialized in Peugeot repairs so please feel free to ask any questions about any faults or problems that you find on your PP2000 or other diagnose tools. Been working over 3 years on these cars, so any new problems are welcome.
    Keep up the good work!
    Alex
  2. The Following User Says Thank You to alexs307 For This Useful Post:
    ker0de (19th October, 2023)
  3. #2
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    welcome to dk m8
  4. The Following User Says Thank You to gmb45 For This Useful Post:
    dany mec (31st March, 2013)
  5. #3
    Quote Originally Posted by alexs307 View Post
    Alex
    carnt get pp2000 to find bsi unit but does live data and engine ecu,abs and power stering. any ideas? its aclone,but it let me regen my 307 hdi
  6. #4
    Default peugeot questions
    hey alex, you could be my lifeline, been doing a lot of searching regarding the paf filter on a pug 307 2.0hdi, do you know much about these things servicing and stuff cleaning etc, thx paulyd2k
    Quote Originally Posted by bigboots View Post
    please give me your VIN so I can trace the wiring diagram...maybe it's a blown fuse or the connection between OBD port and BSI is broken...it's best to know the chassis number before we get started
    for all of you that are asking for help, please also post the VIN when we are talking about a car, so I can find out what type of car is it.
    thanks!
  8. #6
    Quote Originally Posted by paulyd2k View Post
    the same thing, VIN first!
    after that, what are you trying to find out? The "filtre a particules" system seems a little bit complicated but in fact it's very very simple! please let me know what are you trying to do or find out in order to help you.
    thanks.
  9. #7
    Sep 2008
    Default Pug 306
    Hi Alex please help i have a pug306 the car wont start engine light on tested with pug planet no fault codes engine petrol vin vf37akfx32429649 build code 7857. Please help!!!! I have checked sparks, plugs, fuel pump, evrything is ok but wont start and if i try to start it blows some smoke thru the airfilter to the front
  10. #8
    thanks!
    VF33CRHSB82401677 307 2.0 HDI 02 PLATE.build code 9264
    i have checked all the fuses i can see,but hopefully you no more
    thanks inadvance
  11. #9
    DK Veteran wizz2c's Avatar
    earth
    welcome to dk
  12. #10
    earth
    suggest vin's to be posted in pm's only a suggestion
  13. #11
    Quote Originally Posted by gzolee View Post
    if smoke is coming out through the airfilter than you sure have a timing problem. check the timing, maybe it's off one, two or more teeth, this is probably the fault...
    if timing is ok, than a compression test should be carried out in order to find out if the valves are sealing proper the combustion chamber.
    please let me know what you have discovered!
  14. #12
    thanks inadvance
    check continuity between
    pin 7 / 40 pins black connector BSI and
    pin 11 / OBD port
    if continuity is ok and you are able of diagnosing other ECU's like engine,steering,abs, etc, then most probably it's a diagnose tool problem ( you said that it's a clone )
    if continuity is not ok, then first check the 10 pins grey connector behind the glove box. if everything is ok there, I would strongly suggest to drive a wire all the way from OBD port to BSI, between the pins listed above, and then try again.
    I am 90% positive that the K line is broken between OBD and BSI.
    Please let me know what you have found!
  15. #13
    Quote Originally Posted by wizz2c View Post
    i don't have a problem with that, if admins think it's ok this way, please post VIN's here, if not , PM then.
    Cheers
  16. #14
    just a quick update it was the scanner not working proprely,and the ecu still never showed up with the new scanner so i removed the ecu and did a reflow and its now came back to life,thanks
  17. #15
    any new problems?
