Results 1 to 13 of 13
    alex_r_2001's Avatar
    New Jersey ,, USA
    Default I/O terminal or Flex ??? what is better
    Hello Im looking to purchse either I/O terminal full or Flex full... I really leaning into I/O terminal considering it seems only pay upfront for license and flex yearly subs.... KTAG full want $10,000 plus so maybe some other time... So my plan is to get I/O terminal full along with hextag yearly license.... Will this be considerable coverage for ECU in the USA?????? My eyes hurt from trying to make sense of everything..... Does flex have more coverage or is it about the same... Please what opinion of what is best..... Thankyou
    Solidarity with Ukraine
    Dec 2018
    Hi. The question is, what will you use it for? Is for map processing. Are you losing ecu? The I / O terminal makes quite a few eeproms after the connector. Only let me tell you that it is more for a car in Europe. Ktag is a mega tool it does the job really just the price. The flex ecu is also good for the price. It has a lot of possibilities, and above all, technical support. And the bench box. Which allows you to read most drivers without opening it. And an intelligent system for checking the correct connection to the ecu. I / O is the simplest device. And there is not much tsar. I know that there is a lot in the Description. It also does pin readings. And Body computers. So you have to consider for what purpose you need it. Best regards
  3. The Following User Says Thank You to elektronik325 For This Useful Post:
    alex_r_2001 (23rd June, 2021)
    New Jersey ,, USA
    I get into the weirdest work sometimes and alot of times its usually after many people have tried and failed so I just like to have what I need when I need it.... I like to stock ECU at the shop I have alot of them. I am looking for eaisier way to extract information of when I need to... There have been times that I swapped BGA chips because I did not have anyway to get information to the donors. Thanks
    Jan 2016
    i have both flex and I/O terminal.
    I have flex full for ECU reading. Very good tool, excellent tehnical support and very easy for work with it. ECU coverage is big and always updating.
    I/O terminal is mostly for body reading, pin extract and reading some old ECU-s (in my case)
    I/O terminal is not expencive so I would take them both for combination...
  6. The Following 2 Users Say Thank You to tomic19 For This Useful Post:
    alex_r_2001 (25th June, 2021), esse (23rd June, 2021)
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by alex_r_2001 View Post
    10000$ plus for ktag...?
    some kind of gold version with brilliants...?
    where did you see this prices?
  8. #6
    Dec 2018
    Quote Originally Posted by figani View Post
    Italians make different prices for countries not in the EU. Probably the broker earned his money by translating from Italy to the USA. And my trouble will be so. I would suggest contacting Alien tech Italy directly. In my country, when I was looking for it, it was more than 2.5 thousand euro. At middlemen.
  9. #7
    figani's Avatar
    Feb 2018
    Quote Originally Posted by elektronik325 View Post
    Maybe a stupid question from my site...
    But you are not allowed to buy where you want...?
    I'm inside EU, and bought almost all stuff outside EU...
  10. #8
    Dec 2018
    Of course you can. Only I noticed when you find a google representative of a given product. Is that the Ktag. Do other products. This is how you contact him for the price. Then you get a lot more for it. I understand the current euro exchange rate in terms of EU kt. Maybe it is different in a country with euro. I do not know that. I only know from my experience. For this, I contact the manufacturer directly. Not an intermediary.
  11. #9
    figani's Avatar
    Feb 2018
    Again I'm not understanding you...
    Why you have to contact them for price...
    You see prices direct in the shop...
    It's round about 3500€ full, +/-10%....
  12. #10
    New Jersey ,, USA
    I ordered I/O terminal full and Flex Full also Pcm Flash...
    Also the one a seen for $10,000 plus was Alientechs KessV2 Full maybe later on I will consider this
    Thanks for feedback
  13. #11
    figani's Avatar
    Feb 2018
    Also the one a seen for $10,000 plus was Alientechs KessV2 Full ...
    kess full with trucks, agricultare, cars, bikes, marine and so on makes sense 10000$ and or more...
    but not ktag as you wrote in first post...
  14. #12
    New Jersey ,, USA
    Hello everybody... Happy Independence Day to everybody here in the USA.... Ok I recieved I/O terminal along with Magic Flex ...does anybody here have a list of what sim cards applies to which software.... I already recieved my activation files... but a little confused about sim cards.... also I am thinking of ordering I/o terminal version 10 interface that holds all the sim cards in 1 unit...
    Here are my Sims please help identifying except the obvious ones that are named... thankyou...I contacted developer but still no answer from him or my distributor....
  15. #13
    May 2017
    You can have a look on website... there is clarification.
