Results 1 to 5 of 5
    KILL_THE_IMMO's Avatar
    spain
    Default edc16c34 dtc remove
    hi all
    plz i need to remove dtc p0093 from edc16c34 thanks
    --------HELP OTHER TO BE HELPED--------------
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    P0093 – Fuel system leak -large leak detected
    Don't think disabling this DTC will solve your problem!
    spain
    iknow but cannot fix it after sensors and pump
    mrjay88's Avatar
    Apr 2018
    UK
    I love this new style of mechanic lets not fix f**k all and just delete the dtc from the ecu if you cant fix it take it to a garage.
    i dont get it why people do this its propper bodgery other than dodgy car sales people doing this to cover up a knackered car to make a sale its wrong
    Apr 2016
    Quote Originally Posted by KILL_THE_IMMO View Post
    hi all
    regulator and rail sensor are not the problem, you have either the tank, or the diesel filter clogged. clean the tank basket and change the filter, you will see it will be fine.
    if the problem persists, or you have some excessive recovery from the injectors, or a third less flow rate from the high pressure pump
  6. The Following User Says Thank You to eculevel For This Useful Post:
    KILL_THE_IMMO (28th June, 2021)
