Results 1 to 11 of 11
    May 2021
    France
    Default Peugeot Bipper - BSI : Factory default eeprom/flash files
    Hello
    After a battery change, the bsi configuration has been partially lost... so I am missing some options/functions. I was able to recover some but not all.
    With diagbox it is impossible to code anything on this car... I had to use multiecuscan.
    The Peugeot Garage has also tried (included online tele-coding) but it didn't work as expected.
    > The solution offered by the garage is to change the bsi (arrives factory coded) for 580€ !!
    I am able to read and write my eeprom and flash, does anyone know how to get the factory files and/or how to modify mine? (which bytes) and/or if there is a special car hex editor able to helping me ?
    Thanks in advance.
    May 2021
    France
    Nobody?
    Txs in advance
    Oct 2016
    post here your bsi dump (original ) i will make it virgin for u to do configuration again
    (must have diagbox to do this steps )
    May 2021
    France
    Cool !
    Here the eeprom and flash dump...
    I hope that this will work because in the garage they can't do anything for this kind of bsi (with diagbox), these arrive coded from factory......
    > The only thing the garage needs to do after the installation in the car is to recode the keys.
    Thank you in advance !
    Oct 2016
    your eprom is 95160 ??
    Oct 2016
    your old pin : 12716
    file is virgin now
    May 2021
    France
    Default Peugeot Bipper - BSI : Factory default encoding files
    Hello, thank you, but my eeprom is 93c86 and my pin is completly different.. will it work anyway?
    Oct 2016
    when u ask for file pls upload your eprom number , bsi label sw ,hw etc so we could help u correctly post your bsi label
    also press thanks & rep when someone try to help u
  9. The Following User Says Thank You to fady eid For This Useful Post:
    xrider (13th July, 2021)
  10. #9
    May 2021
    France
    Thanks for your answer.
    Sorry you didn't ask for the eeprom number or bsi label.. I will try to do my best in the future.
    Could you please answer my last question ? How should I configure the bsi now (I have diagbox) with this kind of bsi (comes configured from factory) ?
  11. #10
    Sep 2016
    France
    I know Xrider, he's a friend of mine, and I've tried to help him with this issue.
    I would like to make a small clarification:
    The functions that are lost are:
    -Outside temperature display
    -Opening windows
    -Unlocking the rear doors.
    Thanks for what you did, Fady Eid, but do you think this new file will recover those lost functions?
  12. #11
    Oct 2016
    yes u need after virgin to do with diagbox to bsi -learning and add keys , configuration for doors , windows , engine many others
