C3 2020 pin request urgency
Results 1 to 15 of 15
    Oct 2014
    1,340
    Default C3 2020 pin request urgency
    Hi mates,
    I'm stuck here with Citroen C3 2020 Delphi BSI-EL3 car renting lost key.
    I use all my tool but no one can extract pin.
    Dealer don't want to provide pincode with paper and only can reprogram new key after 10 days.
    I'm looking for someone can provide pin from VIN with cost.
    If you can, please write in private. Thanks
    Be polite. No Thanks + Rep, no HELP!!!
    fred77's Avatar
    Jun 2019
    444
    Dealers stopped giving codes
    Abrites or Smok would probably do the job tho not tried C3 that year. But if your doing these kinda jobs - then worth investing
    Tools: AVDI, AutoHex (Full), SmartPro, ZedFull, Im608, JLR SDD, DiagBox, Trucode, VVDI 2, VVDI MB, ACDP, and other crap
    Eeprom: XEP 100, VVDI Prog, MiraClone, Orange, Tango, TMPro (some), AK90
    Others: Gysflash 101.12, PowerStar LW 3000W
  3. The Following User Says Thank You to fred77 For This Useful Post:
    lion0304 (7th July, 2021)
    Apr 2016
    uk
    629
    With smok done a vivaro 2020akl , Citroen dispatch 2020 AKL.
    Gave pin in under 3mins.
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  5. The Following 3 Users Say Thank You to comizelu For This Useful Post:
    lion0304 (7th July, 2021),p1et (11th July, 2021),TERMINATOR1000 (7th July, 2021)
  6. #4
    Oct 2014
    1,340
    You use PT00019 for this Delphi 2016+?
    Apr 2016
    uk
    629
    Quote Originally Posted by lion0304 View Post
    I've got it full mate,not sure..
    On the vivaro I had to choose Delphi 2016+.
    It didn't worked on Delphi 2018+
  8. The Following User Says Thank You to comizelu For This Useful Post:
  9. #6
    Oct 2014
    1,340
    My Smok is on the way, i purchase only for PSA PTP2 pin read that what i need.
    See the option Delphi 2018+ is for Opel.
  10. #7
    Ecuprog31's Avatar
    Mar 2018
    134
    Opel Vivaro after 2018 is the same as jumpy / expert
  11. #8
    DK Veteran afonso rico's Avatar
    guimar„es
    153
    you try this way
  12. The Following User Says Thank You to afonso rico For This Useful Post:
    lion0304 (14th July, 2021)
  13. #9
    Oct 2014
    1,340
    Update this thread:
    Car after go to dealer and program the after market remote key 4A. Yesteday come back for seconde remote key.
    Pin read with X300 pro4, im508, X100 Pad2. The X300 is fatest, around 15s.
    Weird that after add second remote key, the first one still operate. But when you press the seconde, the first stop working.
    Need insert to resync. Seem this model cannot operate 2 remotes at the same time???
    Does anyone met this problem? And where we can find transponder 4A for PSA?
  14. #10
    p1et's Avatar
    Oct 2013
    1,866
    Did you program xhorse/keydiy remote?
  15. #11
    Mar 2018
    UK
    637
    I programmed 3 new genuine remote keys + the original one total 4 remote keys on Vivaro 2020
    I can't belive that this car is proected for only one remote key
  16. The Following User Says Thank You to Manta1600 For This Useful Post:
    lion0304 (22nd July, 2021)
  17. #12
    Oct 2014
    1,340
    Quote Originally Posted by p1et View Post
    For Xhorse smartkey for 4A, it's work well. Tested and report by some here.
    But i use Chinese 4A after maket from MK3. Very bad quality build by KYDZ board. Maybe that why the problem.
  18. #13
    Oct 2014
    1,340
    Quote Originally Posted by Manta1600 View Post
    Genuine one cost me 50$ without 30% tax import. So it's expensive, i use after market from mk3.
    Maybe that is the problem? Next time will only use xhorse mart MQB.
  19. #14
    Mar 2018
    UK
    637
    I have one from MK3 but still waiting for the car to check it
    Never tried Xhorse on these but there is few positive feedback so must work
  20. #15
    newone's Avatar
    Oct 2016
    369
    xh work really good
