Results 1 to 9 of 9
    Jul 2021
    Default Satlink ST-5150 Firmware , Dbtool , Db Europe and America .
    Hello everyone , I make my little contribution.
    Theses files is for SatLink 5150.
    Satellite database Europe and America , C band are incomplete and some American satellites are also , but it is enought you guide. ( As i am Spanish , database starts in Astra 19,2 , sorry )
    https://mega.nz/file/mSImEJQL#UWayEo...X6eErLl21Id_Ps
    Firmware version 2.8 ( If you already have it , it is not necessary to reinstall .
    https://mega.nz/file/fHxUgIoC#q_3P9u...8oc1hcqCsC14XU
    tool to edit satellites , you can edit the order of them and add more , but remember that Satlink 5150 is limited to 107 satllites ( You will not be able to add transponder , because they cannot be safe ) REUPLOAD, thx
    https://mega.nz/file/ueBwHBjI#iIlrLB...Dn697D2F4nbwYc
    Thank you very much an enjoy it .
    *I am not responsible for any damage it may cause.
  2. The Following User Says Thank You to salchicho2000 For This Useful Post:
    sergiy1103 (9th August, 2023)
  3. #2
    Nov 2021
    Is any one having problems with DB tool provided in link above? I did register it, but i cannot opet userdb file also provided. This is no good.
    Aug 2023
    Firmware version 3.2 for ST5150_S2_T2_C_Satlink_V3.2_English_220730(Eroupe_ 30w_75e_220526) for the hardware version of the device ABC-GB0-A-0
    https://dropmefiles.com.ua/en/RsW4aQVMk3
    Oct 2023
    Hallo, have same problem. Donīt work. Can not open bin file
  6. #5
    Oct 2023
    Quote Originally Posted by sergiy1103 View Post
    Hallo,
    unfortunately link is not working. Can you reload it ? Thank you. Do you have an channeleditor that works ?
  7. #6
    Jan 2024
    Question
    Hello.
    Is there still a copy of firmware 3.2 for ST5150?
    I can only find the firmware for the possibly identical Summit Digital SCT-845, but if there is a version for the SatLink ST5050, I don't want to experiment with other firmware.
    And is there any other editor that accepts the bin file?
    Is the non-functionality of "SatEditor" due to operating systems that are too new (Windows 10 and 11)?
    EDIT:
    I found a download here:
    https://satsis.info/forum/pribor-dly...mbo_02-01-2021
    I downloaded it and made a zip out of the 7z to upload it here.
    Is it possible to check the authenticity?
    And does anyone know the editor that can be seen there as a screenshot?
  8. The Following User Says Thank You to Tobias Claren For This Useful Post:
    rosaolivares (9th August, 2024)
  9. #7
    Aug 2024
    Quote Originally Posted by Tobias Claren View Post
    Hello.
    EDIT:
    Does the download still work? Thanks for everything
  10. #8
    Oct 2024
    Poland
    HI. what does the new firmware change? My st-5150 has been weak lately, it searches for satellites
  11. #9
    Nov 2024
    gracias por la actualizacion del firmware,me la llevo
