Results 1 to 10 of 10
    Default ISUZU 1.7L EDU ECU Need Help!
    I'm new in this section, I'm curious how to open ISUZU 1.7L EDU ECU 8971891360 16267710
    tnx in advance
    DK Veteran wizz2c's Avatar
    earth
    you can only remove the rear plate it is seal on but bit of careful force it will remove. you can usually repair just the pcb behind the cover
    Thank you for your prompt response, I noticed that the cover off the back side, but it's hard to take him off, afraid not to damage PCB, whether there is a way to cap off without using excessive force?
    ok i figure it.... tnx for help.
    earth
    do ya know what to repair?
    i find this
    http://www.digital-kaos.co.uk/forums...olution-87103/
    on forum using search, but there is no repair solution.
    on my ECU I find couple dry / broken solder joints and i fix it.
    (if there something else pls tell me)
    And can't wait tomorow to test ECU
    I'll tell you tomorrow what I have achieved
    earth
    yeah in most cases its just the dry joints just resolder using plenty of flux and test all should be good .worked for me 99 percent had one that was just too burnt to repair hope this helps,,good luck
    It's dry joints
    Tnx for support
    Astra working perfect!
    is it fairly simple to identify the dry joints-when you've opened the ecu
    Default como quito la pcb de la centralita
    Quote Originally Posted by bongobongo70 View Post
    hello, I've got dismantled the back cover of the switchboard, but I think it would have to be welded by the inside, which I can not remove the PCB is welded on the other side, somebody knows as I do?
