93c66??.........
93c66??.........
Toyota MMT Clutch Replacement Guide for Clutch Kits ...
try it for me it always works, after replacing the clutch disc you need to reverse the clutch motor by 12mm,
soory bad englisz
so often it happens that I had no display so several times the procedure comes back display but I have to tire a bit, I always started with learning the position of the clutch
with what tool you make learn clutch?
sorry for me bad english.
21 position for OBD shorting I made a switch on long wires
I try OBD shorting method,but not success..
hello is there a sound? the procedure begins? I found it on dk maybe it will help you something
Thanks,but cant open,archive is damaged.
maybe now it will be ok?
problem solved.the mechanic will mixed the gear actuator connectors.for that reason, learning could not take place,I bought other gearbox ecu,for reading good eeprom,write good 93c86 in to ecu,connect gear actuators connector correctly.and car start without problem,then learning ecu clutch and gearbox with launch without problem.Thanks all for help and discussion.
