Results 1 to 13 of 13
    Sep 2020
    Default Digiprog 3 question
    Hi guys i have a digiprog 3 clone and would like to know what is the fastest simplest way to send a eeprom file from the digiprog 3 to my pc ? i was told the program is called digiloader but can not seem to find that anywhere on the internet ? i don't want to edit files just simply move them off my digiprog 3 to my pc any help would be most apricated
    Dec 2016
    Default press thanks and rep+ if i helped
    here friend but notice that your digiprog 3 should have FTDI chip to can transfer your files to pc
  3. The Following User Says Thank You to taiko2010 For This Useful Post:
    donkeypower (19th July, 2021)
    Sep 2020
    Quote Originally Posted by taiko2010 View Post
    Thank you very much for the .rar files i have run both programs but i cant seem to see anywhere where i can transfer files back and forth ? does anyone have any information on how to do this ? i keep seeing people on videos useing a compleetly diffrent software called digi Loader looks very straight forward
    bmwparts's Avatar
    RSA (where men are men and sheep are nervous)
    I've never had success transferring data from clone (have 2 clones and tried many drivers) I write to chip and read with codiprog / carprog / xtool or any other reader.
    If things seem under control, you are simply just not going fast enough!!
    Sep 2020
    Quote Originally Posted by bmwparts View Post
    Yeah i kind of gathered it is a bit of a useless battel tyring to get it to connect to pc, all i am trying to do is change the mileage on a citreon DS4 2016 BSI continental eeprom 95256 but the only bsi on digiprog 3 with 95256 i can see is under Peugeot 508 but when i try to take a read to change the mileage it just comes up (unknown device) so i took a read of the eeprom and saved it hoping i could send it over to my pc and one of you guys here could change the mileage for me but as you can see im stuck with the file on the tool and cant get it over to pc, is there any other car or bsi on this digiprog3 i could try and change the mileage under ?
    Dec 2016
    Connect digiprog first, in special menu enable pc terminal and then start eetool2.exe and choose right com port where device is located.
    With it you can download/upload/delete dumps from device.
    When you install eetool just put this file in the same directory and create shortcut to it.
  8. The Following 2 Users Say Thank You to taiko2010 For This Useful Post:
    donkeypower (19th July, 2021), incapacitor (29th January, 2025)
  9. #7
    clusters's Avatar
    Mar 2015
    Canada
    Only if your Digi has the FTDI chip and 93c46 buffer, a lot of clones do not.
  10. The Following User Says Thank You to clusters For This Useful Post:
  11. #8
    Sep 2020
    Quote Originally Posted by clusters View Post
    hgi i have this chip on my clone tool and i have downloaded eetool2 and installed the program, when i connect my digiprog 3 to my pc and turn on pc term on in special functions my pc says that it is connected to com port 3 when i load up eetool2 it says wrong com port please select another so i select com port 3 but it still fails to connect ? am i doing something wrong ?
  12. #9
    Sep 2020
    any help please
  13. #10
    Sep 2020
    Really struggling here guys my clone tool is the correct tool with the FTDI chip when i connect it to my pc it says driver are installed and its on com port 5, if i load up eetool2.exe it says please select another comport so i select com port 5 but it says fails to connect ? what possibly is there that's going wrong ? the thing that's annoying me the most is 2 years ago i had this tool set up somehow with my old pc and i have personally transferred files back and forth so i know it can be done !!!!!!
  14. #11
    Sep 2020
    This has been resolved and is all working as it should
  15. #12
    clusters's Avatar
    Mar 2015
    Canada
    Would be nice if you shared the solution, to help others!
  16. The Following User Says Thank You to clusters For This Useful Post:
    donkeypower (20th July, 2021)
  17. #13
    Sep 2020
    So in my experience i had to simply download the digiprog3 setup and in that it gives you the drivers for the usb, after that was done i downloaded eetool original so i get the English language File, then download eetool2 and place the english file inside that file. i then connected my digiprog 3 to the computer and checked what port my digiprog was connected to in my case it says (com port 6) then go on the digiprog3 tool under special functions and press ( PC TERM ) after you press that do not touch anything els to not press the Tick arrow as this turns PC TERM back off, Then load up eetool2.exe and select your com port that your digiprog3 is set to and jobs done it loads up and brings up all your files from digiprog 3, so the main problem was i was pressing PC TERM on and then selecting the tick arrow which actualy turns it back off even though it says its still on, i hope this helps someone in the future.
  18. The Following 2 Users Say Thank You to donkeypower For This Useful Post:
    clusters (21st July, 2021), kur715 (31st August, 2022)
