Hi, can somebody help me change hours on this type of dash,procesor mc 68HC711KG4 MASK 0H86A ? is the same as New Holland 8620...
Oem hours 6376 ,i need 4500.
Thank you in advence.
If u have the answer say Thank You!!
Put the dashboard back on the tractor, run at least one hour and then read the mcu again and post here.
ovi_dk (16th October, 2019)
Thanks for help,i solve my self the problem,the algo is the same as N.H. if someone deal with this,here is the dump calculated .
Regards.
Si alguien puede ayudarme con las conexiones del programador , le estaré muy agradecido
