Results 1 to 3 of 3
    Feb 2020
    Default fiat grande punto 1.4tjet fault code p0240 problem
    i have new map sensor and baro sensor
    the car goes up to 130 km per hour and not faster than thatthe engine light also comes on sometimes
    the car does not drive as before has no power and it seems that the turbo pressure is gone
    I don't know what the problem is because I also put a new turbo in it
    can someone help me please
    Aug 2015
    It would be best to log specified and actual boost pressure and compare them
    Feb 2021
    i found this info, i hope it helps you, best of luck to you
