Results 1 to 5 of 5
    Nov 2019
    Default Audi A4 B8 airbag 8K0 959 655B transfer coding from eeprom ,coding problem
    Hi, I have a problem with Audi A4 B8 , car has faulty airbag module. I replace module with another one , copy CP from old to "new" and I cant change coding in "new" module.
    CP is okay, there is no error now ,and VIN is ok.
    Now there is 2 dtc B101100 and B101000 and MIL is ON, I cant change conding or deactivate these airbags with VCDS. When change coding VCDS says "error 22 coding rejected"
    Is there possible to transfer coding from old eeprom to new eeprom ??
    fuzz1's Avatar
    Jul 2019
    Are the modules same?
    I would have just swapped the eeprom if they were same. What do you mean by CP?
    svenin53's Avatar
    Apr 2020
    Ukraine
    You have encountered such a thing as Component Protection.
    VCDS is not able to bypass it, you need Vag Can Pro.
    Or completely clone the blocks, in which case you will not need to encode anything
    Apr 2019
    Quote Originally Posted by jacob21 View Post
    Hellow mr
    Sent from my SM-A125F using Tapatalk
    Nov 2019
    When I write eeprom from old damaged module to "new" module there is errors that I cant erase ( old errors "internal fault " and "voltage to high" from past 1 year , module reject erase )
    Can someone fix eeprom from old module or which part of eeprom I have to copy to have old coding ?
