Results 1 to 4 of 4
    Oct 2015
    Default SID206 Focus 2 1.8TDCI immo resync after Kess
    Hello!
    After flash new file by Kess immo lamp blinking and not start. I put back in recovery ori file but not effect, immo blinking. I hope is only resync becouse I've communication with PCM, no faults.
    DTC about security only in clustrer.
    In attachment files from trasdata:
    eeprom + flash.
    If somebody can help will be great.
    May 2020
    tot557545@gmail.com
    hi friend read dasch eeprom and ecu eeprom for sync and upload
  3. The Following User Says Thank You to ecuprogramer For This Useful Post:
    trotyl (27th July, 2021)
    Apr 2014
    Spain
    Disconect batery for 5 minuts
    NEED PASSWORD ? PRESS THANKS AND ADD REPUTATION
  5. The Following User Says Thank You to danielif For This Useful Post:
  6. #4
    Oct 2015
    Quote Originally Posted by danielif View Post
    not working, not this time.
    However, problem is solved.
    I use ELMconfig, ecu response but not give me VID, I can not read or write VID data and VIN also.
    I download calibration file from:
    http://civil.iffc.ru/ELMConfig/Calibration%20Files/
    and did like this:
    I open ori file what was firstly read by kess, elmconfig recognize VID data, next I load to elm config PHF file from website but keep VID data from ori, and I push "write current firmware to PCM". After 93 minutes shity ford start. How possible self sychro, Im not sure. So I'm so good. Thanx for reply!
  7. The Following User Says Thank You to trotyl For This Useful Post:
    danielif (27th July, 2021)
