here you go
dont 4get thanks and rep
Hello to all. I need wiring diagram Hyundai Sonata EF engine 2.0 16v DOHC, cant find any diagrams online. Car has ignition coil driver signal problems (only on one coil has signal), wiring test to ecu is ok. In ecu small transistor is giving signal to coil ( transistor is sot-363, not driver transistor for coil) Need wiring diagram to see how the ignition coil is driven. Any info will be appreciated. Thanks in advance.
here you go
antonypaul (27th July, 2023), PSAcars (31st July, 2021)
Hello to all. Alex this is older then my car. My is 2004/2005 with KEFICO engine ecu with 4 connectors. Do you have diagram for this type?
Yes .. I will upload a little later.. no problem
maybe with vin I can help you more... My diagrams are based off USA database so maybe different then your area... I was able to find for that year range 4cyl 2.4 wiring diagrams with 4 connectors but im not sure if its the same as you need.... hopefully this will help... goodluck
Last edited by alex_r_2001; 1st August, 2021 at 05:16 AM. Reason: added additional diagrams
PSAcars (1st August, 2021)
Hello to all.
VIN : KMHEM41BP4A034319
hello maybe it will help you Attachment 826494
PSAcars (6th August, 2021)
