Results 1 to 7 of 7
    Nov 2015
    Default audi a4 bcm2 dump repair 02811 error
    Hi guys
    Please can someone repair this bcm2 dump with steering lock defective error
    fault 02811
    thanks in advance
    KriptoKey's Avatar
    Feb 2012
    Please post your VIN number and i help
    Nov 2015
    WAUZZZ8KX9A054983
    Sent from my SM-G930W8 using Tapatalk
    KriptoKey's Avatar
    Feb 2012
    Please write only eeprom in BCM2
    good Luck
  5. The Following User Says Thank You to KriptoKey For This Useful Post:
    lylezim (29th July, 2021)
    achaccha's Avatar
    Nov 2010
    Is it possible to know what are the reasons for this information to be corrupted?
    It can be seen that the VIN number is totally corrupted. but I think that also the immo data may have been corrupted. Why does that happen?
    Is it because there are problems with the vehicle's battery for example?
    thanks for comment
    KriptoKey's Avatar
    Feb 2012
    Your new reading that you have published editing the first post is much better but it has errors and it will not work. maybe someone can repair that file and you can solve your case.
    regards
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by achaccha View Post
    thanks for comment
    VIN in his file is ok
    ESL on these cars will go defective also (MC33689) but not in your case...
