Results 1 to 6 of 6
Hybrid View
    May 2010
    Default Astra H Z17DTR Denso problem with dpf
    lm have problem with dpf in Astra H Z17DTR Denso end please help with off dpf
    May 2020
    Poland
    Here is your file with dpf off
    CHKS OK
    Please, click thanks and reputation button and write to me on PM i will send you the password.
    Greetings.
  3. The Following User Says Thank You to krzys1540 For This Useful Post:
    kamionk (11th August, 2021)
    May 2010
    thanks for help im send you thx end rep please pass
    May 2020
    Poland
    I have already sent to the pm
  6. #5
    May 2010
    big thanks im test end reply
  7. #6
    May 2010
    this very bad solution because not generic fault code from all sensors if disconnect
