Results 1 to 12 of 12
    Oct 2020
    Default Opel Corsa C display safe
    Hello friends, i need little help.
    i want to change my display, old one is dead. I have pin code from old and new display. But when i try to pair it with opcom i cant do it. So i dont know if i can solve it if i virginise old radio unit (CD30 MP3) and try to pair it with new display code. Or if i can somehow virginise new display?
    Thanks for help !
    Oct 2020
    After few hours i whrite everything back to original dumps, i can now barely see old display and with original dump in radio and old display i still get display safe error, so i think that this radio might not be original from my car. I can not find pin code in radio so i cant ce sure. If someone can compare pin code from radio and old display i would appreciate it. Radio is working fine, the only thing is that error. You have all dumps in rar file. Thanks a lot for any help
    GM003090223246
    NO:13 292 090
    WALES
    Quote Originally Posted by Blanco View Post
    Thanks for help !
    If the Display is the same model then just swap eeproms....
    wbr
  4. The Following 2 Users Say Thank You to shooting For This Useful Post:
    Blanco (14th August, 2021), M1DJF (12th August, 2021)
    Oct 2020
    Display Is the same like old one, but position of eeprom inside Is not. I think that radio has been changed and old display wasnt paired with it. Maybe i can swap eeproms in display and make radio virgin. Will that do ? Old display have same PIN like car.
    Thanks for reply!
    WALES
    Thanks for reply!
    Post dumps from BOTH screens....
    wbr
  7. The Following User Says Thank You to shooting For This Useful Post:
  8. #6
    filutek's Avatar
    Silesia
    RADIO pin 7316
    OLD DISPLAY pin 3842
    NEW DISPLAY pin 5455
    P.S... display unreg. change address 0xFF with 8C on D5.
    IMMODATA ACDelco EXX<=>BCM / BCM MERIVA B REPAIR. ALL CRC-I see it ...
  9. The Following 2 Users Say Thank You to filutek For This Useful Post:
    Blanco (14th August, 2021), bogege (13th August, 2021)
  10. #7
    Bulgaria
    Thanks for help !
    As you can see from the last post we have three different codes !! This means that there has never been a proper operation of the radio and display in this car!
    Use this dump for radio..............
    And try to pair it with CAR pass!!?
  11. The Following User Says Thank You to bogege For This Useful Post:
  12. #8
    WALES
    Quote Originally Posted by filutek View Post
    RADIO pin 7316
    Post BOTH displays (Original unedited)
    wbr
  13. The Following User Says Thank You to shooting For This Useful Post:
    Blanco (23rd August, 2021)
  14. #9
    Oct 2020
    First od all thanks everyone for help, car will be driven back to my garage tomorrow, i really want to finish it this time, so here is original dumps for shooting... I'm going to try every solution, one of them MUST work...
    HUGE thanks to bogege and filutek for help..
  15. #10
    WALES
    Use this dump in your NEW display, no need to do anything,
    then pair using 3842 with Virgin radio from Bogege (Post#7)
    wbr
  16. The Following 2 Users Say Thank You to shooting For This Useful Post:
    Blanco (23rd August, 2021), bogege (14th August, 2021)
  17. #11
    WALES
    Quote Originally Posted by norbi3459 View Post
    Hello...I have a big problem with my car. Can you solve IT?
    Opel Corsa D 2011 Touch and connect bosch
    S/n:2640981
    Device:7612830110
    Date:11.03.25
    Wrong thread.... stick to ONE!
    wbr
  18. The Following User Says Thank You to shooting For This Useful Post:
    catalinosonesti (15th August, 2021)
  19. #12
    Oct 2020
    Just wanna thank you guys, job had been done few days ago, everything is working fine. Thanks for help!
  20. The Following User Says Thank You to Blanco For This Useful Post:
    shooting (23rd August, 2021)
