Results 1 to 13 of 13
    Mar 2018
    UK
    Default Toyota VIN to key code
    Any trusted source to pay for Toyota VIN to Key code?
    I don't have the V5 the car is from auction and will need few weeks to receive the V5
    fred77's Avatar
    Jun 2019
    lishi ......... or is this smart key then ok
    Solidarity with Ukraine
  3. The Following User Says Thank You to fred77 For This Useful Post:
    Manta1600 (12th August, 2021)
    Mar 2018
    UK
    As I wrote in the other thread I pick it but not possible to decode no bounce no respond
    Maybe I have wrong lishi TOY43AT
    Dec 2010
    Nottingham
    as wrote in other thread , may be worth trying toy43 8 cut lishi tool and not toy43at, also worth a shot with mit11r lishi as daft as it may sound.
    if worn lock , this can happen , especially if tool is able to rotate a fraction inside the plug , which is one of the symptons it sounds like you may have , if tool rotates slightly in plug it can fail to pick up wafer correctly , if all positions bounced fine , bound and picked with feel on each wafer , then this is a possibility too, if room , once you have inserted tool to pick , also insert a small shim to keep tool square once picked and turned.
  6. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  7. #5
    Mar 2018
    UK
    After pick no bouncing also the wafers are on the wrong place
    As I wrote looks like TOY43AT is not the right one
    Today I had Prius 2007 AKL - TOY43AT is very easy when is the right tool
  8. #6
    Dec 2010
    Nottingham
    its also possible that its a bady worn lock , really the toy43at shouldnt pick the toy43 8 cut and vice versa as spacing differs enough to make line up bad throught the pick process , if you had the TOY43AT 10 cut ignition tool it would have made short work of the ignition if the 10 cut ignition.
    dont rule out badly worn lock , too much play inside the plug causes havoc , thats when to go old school , strip lock or impression
  9. #7
    Mar 2018
    UK
    For sure is not worn lock as the same filling are on 2 front doors and tail gate
    Also usually TOY43AT is 2 by 2 on this one is like 1 by 1 pins and they are out of gird
  10. #8
    alex_r_2001's Avatar
    Jul 2010
    New Jersey ,, USA
    Maybe there is crap at back of lock.. some brake cleaner with the straw to clean it out .. then some houdini lubricant or other good lubricant.. Ive had locks that have had tons of junk inside making decoding impossible.. after cleaning was able to decode...
  11. The Following User Says Thank You to alex_r_2001 For This Useful Post:
  12. #9
    kemaster's Avatar
    Mar 2010
    BG
    Quote Originally Posted by Manta1600 View Post
    Hmm, doubt this is the case but I've met older rav4 4c system with 1 up 1 down and split wafers
  13. The Following User Says Thank You to kemaster For This Useful Post:
  14. #10
    Dec 2010
    Nottingham
    if spacing was out then either not got full insertion or its the 8 cut lock that uses different spacing, toy43 8 cut tool is likely the correct tool
  15. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  16. #11
    Mar 2018
    UK
    Yes TOY43 8 cuts card 67 is the right
  17. #12
    Dec 2010
    Nottingham
    they are rare on your year of rav 4 , but still found on models 2004 to 2006 .
    did you get it sorted
  18. #13
    Mar 2018
    UK
    Quote Originally Posted by rapidlocksmiths View Post
    Yes I posted more info in the other thread
