Results 1 to 4 of 4
    Oct 2019
    England, London UK
    Default Help needed with my car and remap stage 2+ small issue TFSI
    I have a small issue with my Audi A3 2.0TFSI.
    I had the car remapped stage 2+ however im having a small issue. When i full throttle full WOT boost the car goes however sometimes on gear change (dsg) the car will loose boost goes flat and if i take throttle off and put it back on it fully boosts again. I think i have solved this with a GFB+ DV valve, it now hardly does it. However, if i light throttle feather the car boosts more and if i put my throttle all the way down it feels sluggish and then goes.
    I think its a MAF issue not too sure. The mapper said he scaled the MAF.
    I did a smoke test and no leaks found. The hybrid turbo is only 4 months old
    Can anyone remap the MAF off for me
    Bellow attached is car specs and the MPPS file made for me. he said i should be 315bhp
    Thank you
    Car: Audi A3 2.0tfsi DSG (stronic) 2006 BWA engine.
    Mods:
    Hybrid turbo
    Vis hpfp internals
    Downpipe decat
    Oversized ram air
    Iridium plugs NGK
    Ttrs coils
    S3 intercooler
    STOCK injectors
    Turbo spec according to turbo express:
    Machined out compressor cover to fit a 56mm billet wheel, new bearing housing with a 360 thrus bearing, cut back turbo wheel new seals. 7+7 and they said they don't recommend anything over 25psi apparently
    Baddog84's Avatar
    Sep 2012
    Germany
    upload also ori file
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  3. The Following User Says Thank You to Baddog84 For This Useful Post:
    accodinguk (12th August, 2021)
    Oct 2019
    England, London UK
    Original file uploaded thanks friend
    Oct 2019
    England, London UK
    Uploaded some previous logs friend
