Results 1 to 7 of 7
    Oct 2019
    England, London UK
    Default Boosting issue TFSI advice anyone ?
    I have a 2.0tfsi dsg. 2006
    Mods are
    s3 intercooler
    stock injectors
    de cat
    irridium sparks new
    ttrs coils
    oversized ram air
    Hybrid turbo (4 months old)
    stage 2+ remap
    My issue is trying to solve boost loss. During logging my boost requested vs the actual is always not matching, for example 2500mbar it will be 2150mbar (take away atmospheric uk (1000mbar) pressure to get true psi)
    Now i did some more tests and i figured out if you feather the throttle press it a tiny bit and gradually build boost it will match fine all the way to the top. n75 logs 94.9%
    Things ive changed 2 days ago
    n75 original new
    pcv original new
    dv valve new original
    pcv hoses both new original
    smoke tested no leaks.
    could this be a mapping issue ?
    Ive included my map and 2 pics one is full throttle where boost is not matching the other is light throttle gradual where it matches
    alonedark's Avatar
    Feb 2017
    easy buy the s3 300 that with stage 1 you have 365v and it does not break or give so many problems, it will be cheaper and will consume less
    alonedark's Avatar
    Feb 2017
    Uy uy uy uy 3000 euros without vat only the turbo and now no works
    alonedark's Avatar
    Feb 2017
    go sell the turbo the car and buy this
    alonedark's Avatar
    Feb 2017
    O este el 300 o el 310cv suben los dos 365cv sin cambiar nada
    alonedark's Avatar
    Feb 2017
    if with what the turbo is worth you already pay half
    alonedark's Avatar
    Feb 2017
    Y lo mejor de las stage 2 o las stages 3 de estos son lo consumos que son los mismos de un Bugatti veyron
