Just seen news that xhorse version of Poldiag locked BCM2 solution will be available soon...
https://www.youtube.com/watch?v=YslTKW_fCnU
I wonder is it adapter going to work for all or just for Locked MCU.
Don't see Touareg in support list![]()
Edit.
I've read their original post, it will support KeyTool Pad Plus and VVDI2+VVDI PROG, an adapter is needed in order to work, but the other solder-free adapter is not essential.
Supports ADD KEY and AKL only for A4/A5/Q5, instead for A6/A7/A8 you can read data from BCM2 but will need a third part for getting sync data.
These are all the infos
Apparently only works on tablet not prog for now
darknezz19 (20th August, 2021)
Here is more details : https://www.xhorsevvdi.com/wholesale...e-adapter.html
Add Key All Keys Lost Read BCM2 data Sync data Read BCM2 data Sync data A4L/A5/Q5 -2013 OBD No OBD/some need remove BCM2 No A4L/A5/Q5 2013-2019 Xhorse BCM2 Adapter No VVDI BCM2 adapter No A6L/A7/A8 -2013 OBD Obtain from working key OBD/some need remove BCM2 Obtain from third party A6L/A7/A 2013-2019 OBD Obtain from working key VVDI BCM2 adapter Obtain from third party
When hawe AKL in cars after 2013 still need sync data, so for what this option?
You still need sync data only for A6/A7/A8 AKL situation, and also with Poldiag with these 3 models you need sync data and need to pay them additional €120 for every calculation..
VVDI Mini Prog has been updated with BCM2 diagrams using the dongle and no solder adapter, so should be released soon![]()
It's not pointless, it's that for those cars you need also a payable service in order to get key sync, and this is also for Poldiag, at least you can read data for key sync calculation
I agree that is not a complete solution and needs to be updated with time, but for that price i think it's worth it, Poldiag is 1500+ euros
"All Key lost for A6 = Obtain from third party"
Will see how this goes , if they planing to sneak thru PolDiag Server , those guys are already prepare for this![]()
pre-orders now being sent out
