hello
is it possible to do immo off for evasion magnetti marielli ecu ?
the car have the key board code and we dont have the code
hello
Hello mate!
You can add ground on pins 1 and 7 in the double relay for fuel pump (an brown relay), little hard to find wires 1-7 but it works.
Try and raports!
Sorry for my english!
thanks friend do u have a picture for the relay to know how to do it ?
So it looks , located on left side of the engine compartment!
Yhoni (24th May, 2020)
Add ground does mean connect negative to pin 1 and 7? and is this only this brow. Relay or there is something else??
Exactly connect negative to pin 1 and 7 an try if yor car started raport, this is only one brown relay...
My english is bad![]()
Hello friend I tried it and it didn't work![]()
In my case, does not light check engine vith ignition on!
Hello.
This is dump is decoded file for IAW 8P.xx 27c512
This dump can erase eeprom of MCU and you do not need programming 68HC11A1 in this case. Just program this dump in flash 27c512 and put that in ecu, connect power to ECU for 30-40 seconds, then disconnect ECU and return back original flash - this is easy imm0ff solution.
BR
Does with this its needed to cut any wires like immo line or not?
Envoy? depuis mon GT-N7100 avec Tapatalk
[QUOTE = Зоар; 1702497]Hello.
BR
BR [/ QUOTE]
Help download the file, please .... zarabotok027@gmail.com
Помогите скачать файл, пожалуйста Помогите скачать файл, пожалуйста ....гите скачать файл, пожалуйста ....
