Results 1 to 2 of 2
    Feb 2020
    Default Mustang 2016 RCM B00D5
    Hi I bought a 2016 Mustang GT, with good air bags.
    And delete all DTC code.
    The air bag light does not go out, and the forscan gives the error: B00D5: 13-8B.
    Performing the tests in forscan, I did not find an open circuit -> or I can not find it. Searching the forums, I found the same problem with the passenger airbag deactivation light. The light has been replaced with a new one, unfortunately the error is still there.
    How to fix it ? Turn off ?
    please help.
    Feb 2020
    Problem has been solved.
    No voltage in fuse from BCM. Bad connection.
    After applying voltage to the lamp informing the activation of the passenger airbag, the error does not return.
